For anyone who is interested the diagrams in the TAF manual for the supply voltage to the motor circuits (thing and bookcase) are incorrect.
Note: I'm using the online manual at ipdb.org. The hardcopy manual I've got is even worse (it shows a red-wht wire as the supply voltage for solenoids 25 and 27, which are noted as the motors in the solenoid/flasher table, but shown as something else on the solenoid wiring diagram, which doesn't even list the motors.).
According to the online manual (solenoid wiring page) the two motors get their supply voltage from J122 pins 5 and 8 (gry-yel wire). If you look at the PDB schematic you'll find that J122 pins 5 and 8 are switching circuits rather than supply voltage.
So something is obviously amiss and what gets confusing is the supply voltage for these motors is a gry-yel wire, but not this gry-yel wire.
After much digging we found the supply voltage comes from J116-2 or J118-2 (gry-yel wires). One of our machines used J116 and the other J118, which is not surprising since these two connectors are identical and often get reversed.
This same supply voltage goes to the opto board and then to the two EMI boards that supply voltage to the motors.
I'll post this info on my site with a wiring diagram when I get a chance.
Quoted from maddog14:Tell you what if I'm right, you give a five dollar donation to pinside, If I'm wrong, I give a five dollar donation to pinside.
Just wanted to be the first to thank maddog for his $5 contribution to Pinside.
