Just cured one fault and then another pops up. Dont know if this is coincidence or not so i'll explain.
When i had 3 balls in the swamp, they would not kick out. I found that the solder on the diode had broken, so re-soldered and back working.
Immediately solving that, during gameplay, i get the Greed function running and only the yellow light for the vault and the lock light for the swamp would light. The green light above the steel ramp does not light up no more, even though the other two still light up for lock. When the ball falls into the saucer for things hand, instead of thing collecting the ball to lock the ball for multiball, the ball gets kicked out back into play. The only way of locking the balls now are in the vault and swamp.
I have checked the wiring and none seem to be damaged or broken. can anyone point me in the right direction of possible causes.? is this beyond wiring and software related?
