Accidentally broke the 555 lamp socket on the electric chair of my TAF - easiest fix would be to buy the bracket with sockets and electrical in one assembly but apparently that is no longer available - bought the bracket by itself and 555 bases - the metal base of the sockets were too large for the holes in the bracket but I think I hand solved that with a dremel tool - the main problem now is that I am trying to use a small bolt (as small as I can find) to attack the sockets to the bracket but it won't let the chair slide onto the bracket - not sure is am too good at riveting which the old one is - if I can get it to fit in the chair then I should be able to solder the wires in and be all set - anyone have any experience with this? - or better yet does anyone know of any source that still may have the bracket attached with the sockets and wires already? Thx for the help
Rick
