So, the bottom left flipper sticks in the up position. It remains stuck after powering off.
Usually, to get it to release, I power off the machine, remove the glass, and manually flip it back to the down position. When doing this, there is a bit of resistance - the plunger is stuck in the solenoid and it doesn't want to let go.
The solenoid appears to be pretty new (bought the machine a month ago, solenoid looks like it is a year old).
I've spent some time searching old threads this morning and don't see a fix for what appears to be a mechanical problem. The fact that the issue persists after powering off indicates to this novice it isn't an electronic issue (fliptronic board, diodes, etc) but IDK.
What would the most likely cause be? Wondering where to start.
