Ok so check part # 42 is tight under the playfield with no space between it and the washer / shaft and not missing or in your cabinet.
Also verify that part # 38 is also tight.
These two screws tighten everything and are opposing screws and keep everything in between nice and snug.
Screw # 38 is internal of the bookcase . To access #38 remove two screws on top of bookcase. When I opened mine it had completely backed out and was laying inside top of bookcase .
Once you have both screws #42 and #38 nice and tight you can unscrew part #37 with your fingers, just back it off a quarter inch or so which will now allow you to adjust the height of the bookcase assembly by turning part # 33 right for up and left for down , you may have to do it a couple times before you get it just right, but each time you adjust height you will need to retighten #37 to hold in place. Once you have the correct position just give #37 a good hard finger tight turn .
Hope that makes sense,
// Error: Image 279290 not found //
