(Topic ID: 223751)
TAF - blowing f102 and f901 after swapping flipper coils
By Parzival
8 months ago
  • 7 posts
  • 4 Pinsiders participating
  • Latest reply 8 months ago by Parzival
#1 8 months ago
Had my TAF all set, but the left upper flipper was way too strong. Swapped out the coil with the lower right flipper, then started blowing fuses. Swapped them back, and same thing is happening still.
I have a new rottendog power board as pictured. The flipper assembly pictures are how they were originally (when they worked) and now are (after I swapped them back and they still are blowing fuses).
Blue coil is upper left flipper (way overpowered, but initially worked). Yellow is lower right (initially worked as well)
IMG_2050 (resized).jpgIMG_2051 (resized).jpgIMG_2052 (resized).jpgIMG_2053 (resized).jpg
#2 8 months ago
Did you get the wires back in the right spots ? If not you may have hurt diodes on coils and drive transistor.
#3 8 months ago
Difficult to see the wire-colors on the yellow coil but quite sure it is wrong connected. ( ORN-GRN on COMMON and BLU-YEL on HOLD ?)
If so, likely blown diode(s) on coil and transistor(s) on fliptronic
#4 8 months ago
I took pictures before I changed them, and the wires appear to be right (or at least how they were before). I'm thinking the one coil (blue) possibly blew it's diodes, then the transistor when I initially changed it. Then when I swapped it back, it blew the transistor for the upper left as well.
I have some TIP102s on hand, so I may swap those out, and put in a new coil to replace the blue one.
If anyone has conflicting pictures of my coil wiring, that would be greatly appreciated to see!
#5 8 months ago
Look at your first pic. The black and orange grey wire are extremely close and exposed. I'm guessing they touched.
#6 8 months ago
Quoted from Parzival:
Yes, In your manual on page 3-10
#7 8 months ago
Yeah, I'm an idiot. Coil was put in reversed, so my wiring (even though it appeared correct up going down) was reversed as well. Took pictures before, just wasn't smart enough to follow them. Gotta learn somehow I guess
$ 54.00
$ 48.00
$ 29.99
€ 95.00
FlipperLED
$ 229.99
West Chicago, IL
$ 14.95
Comet Pinball
7,000
Lee's Summit, MO
$ 28.00
$ 55.00
Pinball Photos
$ 8.50
Bright Lights Pinball
$ 369.00
$ 109.99
$ 16.00
$ 125.00
pinballmod
Toms River, NJ
$ 40.00
Great pinball charity
Pinball Edu
