(Topic ID: 235343)
TAF blowing F101 on left flipper hold
By bobnatlanta
5 years ago
  • 6 posts
  • 3 Pinsiders participating
  • Latest reply 5 years ago by robertmee
#1 5 years ago
Game is working 100% other than this issue. Recently completed PF swap, including changing out the lower left flipper assembly. The flipper works fine until I hold it. After 5-6 seconds, the flipper dies, F101 is blown. I’ve verified that it’s the correct coil and is properly wired. What else do I need to be checking?
Thanks!!
#2 5 years ago
Fliptronics issue perhaps or a bad coil diode. TAF had the fliptronics I board and would do some funny things if a coil diode was bad. I'd start with checking the diodes. Then test the transistors on the Fliptronics board to see if any are shorted. Check the EOS switches as well, but not sure if they switch the coil power on a TAF...the fliptronics I was only pertinent to TAF I believe so not as familiar.
#3 5 years ago
Quoted from bobnatlanta:
I would double check that coil wiring, especially if it was working prior to the playfield swap. If you know for a fact its wired correctly, you can always do a comparison check for both the primary and secondary windings of the LL and LR coils and see whats different ... the measurements differences between these two coils will guide you to the solution.
#4 5 years ago
I'd dismissed the diodes because the whole assembly is new, but it's certainly possible the coil diodes are bad anyway. I will check that out. And I know the wiring is correct, thanks!
#5 5 years ago
Replaced the coil diodes this morning, and the flipper is fully functional. Thanks!!
#6 5 years ago
Great to hear!
$ 9.95
Metal-Mods
$ 25.99
Lee's Parts
Uberlaser
$ 24.00
Various Novelties
Pinball Photos LLC
8,500
Vancouver, BC
$ 1,159.00
$ 29.00
Filament Printing
$ 145.00
Twisted Tokens
$ 329.99
$ 119.00
pinballmod
$ 27.99
Rubber/Silicone
Comet Pinball
$ 399.00
$ 26.99
Lee's Parts
$ 95.00
Twisted Tokens
10,000 (OBO)
Roselle, IL
$ 84.99
GMods
$ 159.00
Sparky Pinball
$ 9.99
Comet Pinball
$ 119.00
Loop Combo Pinball
$ 45.00
Twisted Tokens
14,500
Pleasant Hill, MO
26,000 (OBO)
Auckland, NZ
This page was printed from https://pinside.com/pinball/forum/topic/taf-blowing-f101-on-left-flipper-hold and we tried optimising it for printing. Some page elements may have been deliberately hidden.
