(Topic ID: 101385)
TAF. Ball is getting lost in swamp.
By garyh999
9 years ago
  • 6 posts
  • 6 Pinsiders participating
  • Latest reply 9 years ago by dmacy
#1 9 years ago
It seems a ball will get stuck in the swamp, usually it will kick it out, but not always, it will start firing the playfied solenoids looking for a ball. It will fire the solenoid on the Thing eject hole usually first then the Thing hand will come out and try to find a ball in the ball eject hole. Sometimes when two balls are in the swamp, it will get really confused. Sometimes a ball will not get ejected into the shooter lane when a ball is locked in the swamp. After a short while it will start firing the solenoids looking for a ball. I have used the switch edge test and observed when a ball rolls into the swamp the switch sees the ball by verifying a closed switch. I'm trying to observe more of a pattern for this. I have been looking for switch issues for this. Any advice or help is appreciated.
#2 9 years ago
Check for loose wires on the kick up solenoid.
#3 9 years ago
Had a similar problem with mine. Turned out the balls in the trough were not moving forward when a ball was being placed in the shooter lane. The thing that loads the ball was not returning all of the way and holding the other balls up. Spent a lot of time looking for switch issues till I found the real problem.
#4 9 years ago
Quoted from garyh999:
I recently refurbished a swamp kickout, and I had found that one of the switches was loose. You might want to remove the swamp kickout, manually check the switch levels, listen to the clicks, and check the switch levels with the system tests. It's good to clean the whole system out, and perhaps swap out a new solenoid sleeve while you are in there as well.
You can see how filthy this one was was here, all that hidden grit is bad for the balls/PF.
https://pinside.com/pinball/forum/topic/tech-taf-swamp-kick-out-weak
Also -- you might want to drop a note in the TAF owners club looking for help (here).
-mof
#6 9 years ago
And to echo what others said, I had done a complete PF swap on my TAF back in October and I found one out of 100 balls were getting stuck but at first I thought I had a flaky switch. I put in new weldments and the one had some spot welds that needed filed down. When the ball would the spot just right it would hold it there as crazy as you'd think.
So not that you have that issue, but could be something physical so check the easy stuff. I do like Rlerman's easy fix too!
YouBentMyWookie
$ 140.00
pinballmod
$ 320.00
Avid Creations Wireforms
$ 41.99
Lee's Parts
$ 9.95
Twisted Tokens
$ 8.50
$ 24.25
The MOD Couple
$ 19.99
Mitchell Lighting
$ 25.99
Lee's Parts
10,000 (OBO)
Roselle, IL
$ 53.99
$ 24.00
Various Novelties
Pinball Photos LLC
$ 27.99
Rubber/Silicone
Comet Pinball
14,500
Pleasant Hill, MO
$ 84.99
GMods
$ 25.99
Lee's Parts
€ 47.00
PPmods
26,000 (OBO)
Auckland, NZ
$ 95.00
Twisted Tokens
Metal-Mods
$ 109.99
$ 58.00
$ 39.99
Lee's Parts
Various Other Swag
JK Pinball
8,500
Vancouver, BC
Twisted Tokens
This page was printed from https://pinside.com/pinball/forum/topic/taf-ball-is-getting-lost-in-swamp and we tried optimising it for printing. Some page elements may have been deliberately hidden.
