Hi,
I think I have soldered my Addams Family to death: the game was perfectly working until a cable fell off of the coil of the upper left flipper. I have soldered it back on, and now ALL solenoids are dead.
After the power-on test, the system says I should check the connector F1 to the lower right flipper, connector F7 to the upper left flipper, and the thing ball eject. All those connectors seem to be ok.
When running the solenoid test, all of them are dead. Flashers and lights work.
I have checked the fuses on the power driver boards - they seem to be ok (though I have only removed F112 for the check and tested the others in place). However, the 50v test point on the board shows no current. The other test points (20v, 5v, 12v) read ok.
Does anybody have a hint what I could check next?
Thanks a lot for your help!
