Picked up an Addam's Family this weekend. Upon test run at the seller's home, there were roughly 4 switch/solenoid warnings. (The leaf switch on the "G" target, one on the orbit) Also the usual "Date and Time not set".
I get it home, replace the batteries, and this cleared all the warnings (back to factory settings). Test runs do not show any of these problems even after several games. Did this clear out all the warnings? I don't see the infamous "dot" after "Free Play"
I'll test the switch I know isn't working tonight alone - (yes work, work, work) I just figured if the switch is bad and you reset to factory, wouldn't it detect the problem again?
