I had an Alien Poker (WMS Sys 6) with Sys11 flipper mechs on it, and it made quite the difference. Of course, at that time, you couldn't get the parts to rebuild Sys 6 flippers to 'new' like you can now.
My game is a System 9 Comet. Clay's says it is mainly for the spring wear:
"Changing to the New Style Flipper Return Spring.
Williams changed flipper return spring styles in 1992. So on system 11 games, there's a cone-shaped flipper return spring that goes over the flipper plunger. The problem with this set up was it chewed up the flipper link, and often the spring just got weak and broke from the constant contact with the flipper link.
To combat this problem, Williams made two changes. First they changed the style of flipper link to be thicker, and have a more rounded contact point. Second they stopped using a cone style return spring. The return spring was moved outside of the plunger, where it takes less abuse and doesn't chew up the flipper link."
I'm just wondering if it is as easy as the guide makes it sound, it says just drill one hole (for the spring) and the kit is a full change out replacement.
This page was printed from https://pinside.com/pinball/forum/topic/system-9-fliptronic-style-flipper-upgrade and we tried optimising it for printing. Some page elements may have been deliberately hidden.
