Working on my first alpha numeric machine. I bought a Gottlieb Big House. I was told it worked fine prior to the MPU and the driver boards being removed. I purchase a new swemmer MPU and rottendog driver board. I installed both this evening and eagerly turned on the the pin. Everything lit up including the display and all of the playfield lights. The MPU board LED's were on, the driver board LED was on, and the sound board LED was on. There was also music playing. I attempted to start a game and it tried to reset, however one of the slingshot coils continued to fire and it never kicked a ball into play. During this time the flippers worked and the playfied solinoids (bumpers, slings, etc) also seemed worked when activated.
I turned the machine off then turned it back on. This time I pressed the test switch and went through the test phases. The lamp test appeared to be fine, the coil test had coils 3, 4, and 7 not firing. I continued to move through the test mode by pressing the test mode button. I then turned the machine off.
Now.....when I turn the machine on I get nothing except a few lights on the playfied. The MPU LED's come on and the single LED on the driver board lights. However, the display is blank, the sound does not work, and no coils fire at all.
I've checked all the fuses and they are good. I have also removed the light ballast as recommended on the wiki site. I have turned it off and on several times and getting the same result.
I am completely lost and have no idea where to begin. I have very little knowledge and no experience in these types of machines. Any help/tips are much appreciated. Thanks...
