(Topic ID: 151503)
System 80b sound only works after pushing SW2
By Qmay
  • 21 posts
  • 4 Pinsiders participating
  • Latest reply 3 years ago by mr2xbass
#1 4 years ago
Just obtained a free Raven (I paid too much I know).
Anyways, there's no sound on boot, red light is solid. Pushing SW2 makes all sound and music work and red light starts blinking.
Also display has garbage characters and sometimes doesn't turn on, not sure if related.
Any help greatly appreciated!
#2 4 years ago
Check the 5volt power supply to make sure your getting a tad more than 5volts, look underside for cold solder joints at pins.
#3 4 years ago
Yes its related... the reset line for the sound board goes via the display cable in a way.. the schematic has exact details
#4 4 years ago
Thanks! Will check it out and report back!
#5 4 years ago
Garbage characters on display could be an issue with the 5101 RAM, but with the sound issue in there too, check the above mentioned first (connectors, power supply, cold solder, etc...).
#6 4 years ago
Ok, spent a few minutes with the multimeter, I also followed a few instructions from pinwiki. FYI I had already done the ground modification in the cabinet (remove molex connectors, ground the wires to the metal frame).
So, checking the power supply board was fine, followed pinwiki instructions:
"When measuring the +5VDC provided by the power supply, first disconnect J2 on the power supply. Measure power at the J2 male headers first. Once within an acceptable range, turn power off and reconnect J2. Measure power across C1, the 100uf/10V capacitor that is next to J1 (power connector) on the MPU. The MPU may drag the +5VDC supply down a bit. If you find this to be the case, adjust the trim pot on the power supply until a steady +5VDC is seen at the MPU. Poor connections between the +5VDC power supply and the MPU board may also reduce the voltage measured at the MPU. "
So things I checked:
1) Voltage at J2 was ~5VDC, voltage at capacitor C1 was ~12VDC.
2) Then checked Reset pin #9 on A6P1 (connector on sound board), was ~5VDC (pushing the SW2 button had no effect on voltage at the reset line).
3) Unplugging display connector had no effect on sound boot.
4) Noted sound board dip switches were On-Off-Off-On (1-2-3-4), changed to Off-Off-Off-On since how they were depicted in the schematic (open open open closed). Not sure if I did this right, just seemed to me they should match the wiring diagram.
5) Noted that the A6P1 (connector on sound board) pin 12 and 17 are bridged, this is bridging the AC and DC ground as per wiring diagram, I assume this is okay, but not 100% sure there's not a ground loop or noise being introduced.
Any thoughts?
#7 4 years ago
Quoted from Qmay:
Pushing the reset button on A6 wouldn't affect the voltage of reset pin #9 as the +5v comes from the driver board and go low when triggered.
Quoted from Qmay:
switch 1 and 2 aren't used, so that shouldn't make a difference.
..I know this information is of no help, sorry.
When you checked the +5vDC coming off the power board, I assume you checked all the +5v outs? (I believe there are 3 or 4)
#8 4 years ago
#9 4 years ago
Quoted from mr2xbass:
Yes, all pins were +5VDC.
And all info is of help, I appreciate it, even if it serves to confirm something is normal.
6) pin 40 on the 6502 chip (reset pin) was +5VDC, Vss pins 1 and 21 were +0.15VDC, need to check what they're supposed to be.
#10 4 years ago
Any other thoughts?
Things I plan to do now -
a. I need to confirm what the 6502 VSS voltages should be.
b. Check sound lines 1,2,4,8 should be high on boot, go low when sound activates.
#11 4 years ago
Quoted from Qmay:
Remember sound 16 in this check too. I don't recall if 16 should also be high on boot and then goes low when used or if it is low then high when used, but 16 is the 5th signal to get 31 sounds. (2^5=32, -1 for all high [silence])
#12 4 years ago
The far right column is for 80b. From papinball.com
#13 4 years ago
Quoted from Qmay:
All pins were high on boot.
I did notice that when I bumped into the cables coming from J2, I heard definite noise in the board and I think even triggered some coils to fire like in a ball search. I think the connecter J2 may be crap, so I need to find a good way to replace it. Will reflow solder pins too.
#14 4 years ago
Haven't had a chance to work on it much this week, but did notice during a quick game that the music doesn't always boot but the sounds work every time (after sw2 push). Power cycle eventually brought music back. When music didn't work, opening coin door started music in attract mode, but music was gone in-game.
I'm going to fix J2 as mentioned above, there must be something to the fact that power cycling changes behaviour. Same for the garbage display, it's different between boot ups. I ordered replacement chips for the display as well.
#15 4 years ago
Did a reflow on J2 pins and took molex apart and rebuilt after checking crimps (seemed good).
This fixed my display! Sound is still having same issue. Lesson learned: reflow J2 regardless of how it looks. I'll repeat with J1 as well.
#16 4 years ago
Quoted from Qmay:
What was the fix, was it just replacing the display ROM?
#17 4 years ago
The reflow on the J2 pins and rebuilding the molex connector fixed my display issue. I used a pushpin to "unlatch" the individual wire connectors from the white plastic molex. Then I stretched out the loop part of each wire connecter to hopefully provide better contact to the pins. This part literally took 1 minute to do. After removing the power unit, for the "reflow" although not a true reflow per se, I used my soldering iron to heat the pin on the back side to melt the surrounding solder and added a drop or two of new solder. Fyi for anyone out there, it's not sufficient to just heat the solder by touching the iron to the solder, you need to make a good connection by getting the pin hot and having the solder melt due to the pin's heat. This is really the case for all good solder joints - don't heat the solder heat the medium.
#18 3 years ago
No luck woth J1 reflow, not sure where to proceed
#19 3 years ago
Just a stab.. maybe the reset line on A6 (pin9 I believe the chart above shows) is not resetting the board as it should. Especially since the board operates after pressing the manual reset (sw2). Although that doesn't explain why the FX work and the music does not. The board has two areas for generating sound: one for the fx and one for the music.
Here's a good read that might help you out, I came across it while searching for information about my Spring Break when I first had the idea to do custom sounds: http://ty-ffasi.com/repair/gottlieb-system-80b-sound-boards/
I just reread it now and there is in fact a section at the end which talks about trouble with this sound board in a Raven caused by the "external reset line being held low by the display unit", and you did also mention trouble with the display... I think this may be the ticket!
#20 3 years ago
That's a good lead, I will check again now that the MPU pins are reflowed. I did at one point disconnect the display and that didn't help, so I have a feeling that it might not work...we'll see.
Also I need to double check that I did indeed check sound line 16 on startup.
I'm going to ask around locally to see if anyone has an 80b I could out my sound board in, that will at least narrow it to a sound board issue or something else.
#21 3 years ago
Also, with your alternative setup (rasppi and wav trigger), if you get that working/communicating properly with the rest of the boards, I would imagine it would mean it's more likely a problem with the original sound board and not coming from somewhere else in the machine.
Gweem's Mods
€ 8.40
$ 299.00
Displays
Boston Pinball Company
$ 89.99
$ 75.95
$ 7,399.00
Nitro Pinball Shop
$ 29.99
Various Novelties
GC Pinball
$ 7,500.00
Nitro Pinball Shop
$ 7,599.00
Little Shop Of Games
