(Topic ID: 238450)
System 80b pop bumper
By hockeymutt
5 years ago
    #1 5 years ago
    Good evening everyone just got 3 replacement pop bumper driver boards and 2 of them fixed my pop bumper issues, the 3rd when I pressed the test switch it sparked and fried the trace from pin 2 (ground). The coil in brand new and have checked for proper ground, cross shorts and shorts to ground with no discrepancies noted. I've also checked the connector to their respective spots and all checked fine.
    All fuses are good with proper ratings.
    Any help would be awesome .
    #2 5 years ago
    Are you sure the diode is the right way?
    #3 5 years ago
    Board has built in diode protection. Shouldn't matter.
    #4 5 years ago
    If the header pins were replaced, was the keyed pin in the correct position?
    #5 5 years ago
    It was a replacement from pinrepairparts he did all the work
    #6 5 years ago
    Compare the components to the failed board to a working board. Is the orientation of everything the same, or are there any differences?
    #7 5 years ago
    Yup everything is the same and keyed correctly wonder if I just got a random bad board.
    #8 5 years ago
    Is the coil in the damaged circuit wired correctly? Sounds like it might be wire up backwards. You mentioned it was brand new. Easy mistake to make.
    #9 5 years ago
    His boards have built in diode protection so it shouldn't matter which wire is on which side of the coil at that point
    #10 5 years ago
    Can you link to talk about this built in diode protection? I don't get how it could do anything a fuse wouldn't if the coil shorted.
    #11 5 years ago
    Diode protection or not. Are you sure the coil is wired up correctly? That would be where I check first. There is a lot of juicie goinging to the coils. What brand pop boards did you get? A photo of the fried board would be helpful.
    #13 5 years ago
    Interesting. I’ve never seen that one before. And the fuse for this pop board didn’t blow when you ran the test?
    #14 5 years ago
    Hahah nope, blew my mind. Trigger led lights with the spoon switch. Getting 25 volts at the coil as I should be. And 5 everywhere I am as well.
    #15 5 years ago
    You can always try one of your known good pop boards in that location if everything seems to check out. Like you said, might have just been a bad board. At this point it is kind of a roll of the dice.
    #16 5 years ago
    The page says "even if there's no diode on the coil", not "even if the diode is backwards". Maybe it protects that too, but that's a very different case.
    #17 5 years ago
    What game is this for?
    #19 5 years ago
    Perhaps the diode on the coil is shorted. Try removing the diode and meter it.
    Quoted from Mad_Dog_Coin_Op:
    It would be better to fix the trace on the board, swap it with a known good board and see if it does the same thing as it did on the non working bumper than to possibly burn another board on a possible bad coil / diode.
    #20 5 years ago
    Removed a diode off a working coil and with a good replacement board is now causing the coil to lock on instantly and blowing the 2amp fuse
    #21 5 years ago
    If you hook the power wire to the wrong side of the coil something bad is gonna happen, as a noob I did it to my f-14 blew transistors twice and a flipper bridge rectifier. Power should be on banded side.
    #22 5 years ago
    Yea I removed the diodes like his website says I can and nots to working like advertised. Causing coil lock on now.
    #23 5 years ago
    Please post some pics of the coil in question.
    #24 5 years ago
    Here it is, got it from Marco. Replaced 2 out of 3. The one that was working had a weaker pop compared to the originals.
    #25 5 years ago
    Quoted from hockeymutt:
    Here it is, got it from Marco. Replaced 2 out of 3. The one that was working had a weaker pop compared to the originals. [quoted image]
    Can you show the coil tabs?
    #26 5 years ago
    Give everyone an update, it was a bad diode on the brand new coil. Chris over at pinballreplacementparts.com was excellent and sent me over new boards after it happen.
    Would have never thought a new coil would have had a bad diode. $.10 in parts caused 2 days of troubleshooting and $40 in parts. I now have 200 diodes of all sorts to have on hand.
    This page was printed from https://pinside.com/pinball/forum/topic/system-80b-pop-bumper- and we tried optimising it for printing. Some page elements may have been deliberately hidden.
