(Topic ID: 209826)
System 80b hi score error (memory failure?)
By bmsx
6 years ago
  • 3 posts
  • 2 Pinsiders participating
  • Latest reply 6 years ago by MarAlb
#1 6 years ago
I wanted to instal battery socket on motherboard to save high scores. I soldered socket, blocking diode and installed new 3V battery CR2032.
On the next day when I turned on pinball display showed this:
WP_20180201_16_30_11_Pro (resized).jpgWP_20180201_16_30_11_Pro (resized).jpg
(Missing digits are different issue, not involved)
Every score looks like that.
What I try:
- factory reset in bookkeeping (every statistic shows "8888")
- changing positions of dip switches
- desoldering socket and diode
- cleaning board
Nothing helped. In test mode I have "Memory - OK".
Did I damage Z5 RAM or it's something else?
WP_20180213_22_20_57_Pro (resized).jpgWP_20180213_22_20_57_Pro (resized).jpg
WP_20180213_22_22_07_Pro (resized).jpgWP_20180213_22_22_07_Pro (resized).jpg
WP_20180213_22_21_34_Pro (resized).jpgWP_20180213_22_21_34_Pro (resized).jpg
1 month later
#2 6 years ago
Without Z5 also nothing changed.
I replaced Z5 RAM but nothing happens. With battery on I can read voltage on Z5.
I have no clues. What other components can be faulty? Anyone?
#3 6 years ago
What voltage do you measure at pin 22 from Z5 when the game is powered off and the Lithium battery is installed?
Using a 1N400x / 1N4148 blocking diode will subtract 0.7V from the 3V battery voltage. The 62 Ohm series resistor is also still installed, maybe the stand by voltage is getting a bit too low. You can try using a schottky diode (1N5817, BAT46, BAT85).
There is also a possibillity there is somthing wrong with the chip selection for Z5. A testrom is a nice tool to check if this is working properly. You can send me a PM with your email address to obtain a testrom for system 80.
The "memory ok" in testmode is probably only a test for the RIOTs' internal memory - but I am not sure Z5 is also covered in this test (you can try to run the test without Z5, the game will boot normally without Z5).
Marco
