I picked up a Spring Break at a reasonable price. I had it woeking 100% after adding the piggy deux card. I cleaned it up added LEDS and now I lost the upper right pop. Dead as doornail. Worked fine before the tear down. Here's what I've checked.
- swapped pop bumper boards. They all work, pop in question is dead on known working boards.
- switched wires on the coils. The coil works
- checked switch continuity, apron/switch is good.
-fuse under playfield was checked with a meter. It's good.
Where do the pops get their power on this system? Anyone else have this?
Manual is on its way. All ground mods are done cabinet and boards.
