(Topic ID: 300208)
System 80B Display Board Capacitor Question
By BleacherBum
2 years ago
    #1 2 years ago
    I am hoping someone can share some knowledge.
    I recently obtained an unpopulated Gottlieb display board from The Pinball Resource (PBR). It is listed on PBR as a Gottlieb System 80B board. When I Compare it to the board in my System 80B pin it appears the same with the exception of a capacitor added at C7 (see attached photo).
    I followed the circuit from it where it enters at A4J1 to it’s end at the display glass . The circuit, as far as I can tell, is the same as the circuit from in the Gottlieb manual (Chicago Cubs Triple Play, CCTP). There in one exception that I see. That is a capacitor added between the incoming input from A4J1/#10) and Z2/pin 9.
    I highlighted the circuit on the board from PBR (see attached picture). The outgoing path on the PBR board from Z2/pin 8 to U2/pin 5 is the same as the the schematics for board CCTP A4 board.
    Since the CCTP schematics does not include C7, I am unsure of what capacitor could be used. If the board is populated with components per the CCTP manual, can C7 be left unpopulated? If not, can someone suggest a suitable capacitor?
    Thanks,
    Phil
    01EFF314-11AA-4DD8-B4CE-B7DC5DCC1F02 (resized).jpeg01EFF314-11AA-4DD8-B4CE-B7DC5DCC1F02 (resized).jpeg0E57EA84-AF99-4351-A61A-4F0FB5CA85F8 (resized).jpeg0E57EA84-AF99-4351-A61A-4F0FB5CA85F8 (resized).jpeg
    #2 2 years ago
    ChrisHibler would be the man to ask about that. Might be good to add it to the Pinwiki, looks like an early revision photo is already there: https://www.pinwiki.com/wiki/index.php?title=Gottlieb_System_80#System_80B_2
    #4 2 years ago
    Thank you very much!
    #5 2 years ago
    BleacherBum Where did you obtain the 10941 and two 10939s for the panel?
    Chris Hibler - CARGPB #31
    http://ChrisHiblerPinball.com/Contact ... for board repairs
    #6 2 years ago
    Quoted from ChrisHibler:
    Looks like a few pinball suppliers have them in stock. Just google gottlieb and the chip numbers.
    #7 2 years ago
    Whoa! The 10941 is installed backwards!!!
    #8 2 years ago
    Quoted from G-P-E:
    Good eye Ed. Hope the OP sees this before they power it up.
    #9 2 years ago
    where did you find the bottom nipple futobas?
    #10 2 years ago
    marco have them
    #11 2 years ago
    Thanks Ed and YeOldPinPkayer for catching my mistake I guess I shouldn’t work late into and into the early morning hours.
    #12 2 years ago
    Hi Chris,
    I don’t remember where I got the 10939 chips but, I got the 10941 from Ed (a couple years ago) he is out of them now. I did a quick search and found these vendors: ( there maybe more)
    flippers.com. List both the 10939 and 10941. https://flippers.com/catalog_oc/index.php?route=product/search&search=10941
    Marcospecalties lists both just search on the IC number: https://www.marcospecialties.com/control/main
    Arcade Chips only lists the 10941, https://arcadechips.com/advanced_search_result.php?search_in_description=1&keywords=10941&pfrom=&pto=&categories_id=&x=0&y=0
    #13 2 years ago
    Quoted from pinostalgia:
    I do not remember where I got mine. I have had the stored away for awhile. These two vendors show them in stock.
    Action pinball lists them: http://www.actionpinball.com/parts.php?item=XO-840
    Marcospecialties also has them: https://www.marcospecialties.com/pinball-parts/GTBDIS20-T
    #14 2 years ago
    Quoted from BleacherBum:
    Ed G-P-E caught it, I just sent a PM hoping it might reach you before you powered it up.
    This page was printed from https://pinside.com/pinball/forum/topic/system-80b-display-board-capacitor-question and we tried optimising it for printing. Some page elements may have been deliberately hidden.
