(Topic ID: 261169)
System 80B booting issues
By JodyG
    #1 4 years ago
    Hi folks, I have a System 80B MPU that is giving me fits at the moment. Right now, there is no boot, no displays, couple inserts locked on, and GI lit up when I turn the power on. No solenoid thunking.
    What I have done:
    Verify good 5v on the MPU
    Swapped MPU into a known good machine and had the same results, so I know it is the MPU.
    Daughter board has been reflowed previously and pressing on it does nothing when trying to boot. Also pressed on it with reset board plugged in.
    Reseated the ROM chips and also swapped in known good ROM chips and no change.
    None of the 6532's seem to be getting hot, as well as the Z11-14 IC's
    I have been google searching for past threads, and I am not seeing much beyond what I have already done. I have had some issues with 6532's before...can the failure of one of U1/U4/U5/U6 cause the machine to not boot at all?
    Thanks,
    Jody
    #2 4 years ago
    JodyG - Here's what I recommend based on troubleshooting two system 80B projects recently.
    Do you have the following: a multimeter, & a logic probe? What level of desoldering skill/equipment do you have? Do you have a test bench(5V power supply)
    To start:
    (1) Buy piggyback deux board from pinitech - this will remove a bad daughter card out of the equation.
    (2) You need to test continuity from U2, U3, U4/5/6 & U1 via pinwiki, link below:
    https://www.pinwiki.com/wiki/index.php?title=Gottlieb_System_80#Continuity_Chart_of_Pinouts_for_Damaged_U2_.2F_U3_Area
    #3 4 years ago
    Quoted from JodyG:
    Where did you measure from? You must measure 5V on the MPU. I have had a few cases where the power supply puts out 5V but at the MPU the voltage is like 4.5V so the MPU doesn't boot. You can measure the capacitor nearest A1-J1.
    Also if you can, post some pictures of your MPU, front and back.
    If you don't have soldering skills or the good desoldering equipment, no worries. If that is the case I would recommend sending your board into someone who can troubleshoot it as well as socket the cpu, u4/5/6 chips.
    #4 4 years ago
    Quoted from Friengineer:
    I measured the voltage at the capacitor by A1-J1. I'll start with the U2/U3 continuity test and see if that shows any issues before go the Piggydeux route. Since that area has been heat cycled once before by someone else, I don't want to do it again and risk removing traces if I do not have to. I down a FR-300 and am comfortable doing good soldering work, I just don't want to start shotgunning good components.
    #5 4 years ago
    Quoted from JodyG:
    Absolutely. And without a diagnostic tool like GPE's QuickScan80 (NLA) or PiniTech's PiggyDeux with Marco's test ROM, you are shooting in the dark. I have those tools and can take care of the board if you'd like.
    Chris Hibler - CARGPB #31
    http://ChrisHiblerPinball.com/contact
    #6 4 years ago
    Quoted from ChrisHibler:
    Thanks Chris! I actually just ordered the Piggydeux with Marco's ROM this morning and will give that a shot. This is like the 3rd time I could have used one of those, so I finally decided to just get one and be done with it.
    #7 4 years ago
    Quoted from JodyG:
    With the piggyback deux board you don't have to remove the daughter board. I would recommend against removing the daughter board at all costs. I removed one & nearly ruined my MPU. Luckily I was able to repair the damaged traces & I have a few replacement MPUs.
    Well you learn something new everyday. I didn't realize, I could combine the two!
    #8 4 years ago
    People love to rag about working on 80B's, but I would 100% rather work on an 80B MPU over a System 11 MPU. The traces are way more forgiving on the Gottliebs.
    #9 4 years ago
    Quoted from JodyG:
    Definitely agree...until you get to the 80B sound boards...those things are boogers....
    This page was printed from https://pinside.com/pinball/forum/topic/system-80b-booting-issues and we tried optimising it for printing. Some page elements may have been deliberately hidden.
