Gang:
I finally found the one System 80 I have been hunting for for years. It's my first machine built on that platform, but I do have experience with the System 1. Unfortunately, the joker that sold me the game took me for a ride and neglected to tell me that the boards were all either missing or burnt to a crisp. So, I had to plunge for new boards and went the Swemmer route. For the record, these boards are gorgeous. I did NOT immediately install them, but waited until:
- All major connectors were repinned - everything but pop driver boards and score/credit displays.
- Every (or so I thought) coil checked and replaced if failed (low ohms) or even appeared to have gotten warm at some point.
- All switches checked for proper open/closure
- New capacitor to replace big blue in cabinet
- All fuses replaced with new correct value specimens
- Validated under playfield transistor is good with DMM
I did NOT do any ground mods as Swemmer shared that with his boards they are not necessary.
So, when I first booted up, I was able to enter diagnostics (play/test switch)
The fuse for +24V (solenoids) blew when I went into solenoid test - this happened twice, afterwards I did appear to have 2 coils that needed to be replaced (knocker and coin door lockout relay). I have no idea why these fried (although I think the knocker was previously dead), but they have been replaced.
Now, when I power on, the reset and tilt relays click, and the coin door lockout engages. I get all zeros on the three displays that work. All of my voltages on the boards are good. The LEDs are lit and I validated with my DMM. The number 15 appears in the credit display (so I assume I have credits). All GI and controlled lamps are present and so is the attract tune. No fuses blow.
However, when I press the play/test switch nothing happens. Press the game start button, nothing happens. Close credit switch, nothing happens.
My slam is closed and PF tilt is open, cabinet tilt is open. Coin slot switches, all open. Outhole switch is closed when ball in trough.
I'm stumped and do not believe anything happened to the boards when the coin door relay fried (again, I believe the knocker was already dead and just missed it in my initial walk through).
Hoping I can get some help here. Usually, I can figure this stuff out, but the Sys 80 is new to me.
Thanks in advance!
