Well I had an old control board and plugged it in and it booted.
Attract Mode:
All voices seem to be working when in attract mode but none in game mode.
All standard and controlled lighting seems to work on both fields. Back glass also but chaser lights are dim and very fast.
Displays. 1st and 2nd player only show one’s (111,111 & cycle to 1,111). 3 and 4 player display show what is pictured so again segments are missing (Control Board malfunction?). Lower Playfield display and Credit/Ball in Play displays are not lit during Attract Mode.
Game Play:
1st Player Display only shows partial segments when scoring. Credit shows only a 1 as does Ball. Its blank when advanced past the number 1.
No voice in game mode.
No Pop Bumpers, lamps are lit and solenoid voltage is available.
Yellow Targets, lit but no points or sounds
Drop Targets, only C&K make sound and score in BLACK and none of HOLE. They only reset on next balls start.
Front Left Bumper makes no sound and no points if it gives any.
Spinner makes no sound and no points if it gives any.
Gravity Tunnel Roll Over (to power up lower player field) does not function (leaf switch is ok).
Last picture is of it trying to show a score while playing.
Questions
Are the display issues all from the Control Board? I suppose these are chip &/or transistor issues. Any idea on how to determine which for which segment. I have a logic probe and a DMM on hand.
Would the fast mooving and dim back board chase lights be due to a weakened capacitor?
Seeing how none of the poppers what to work and only light up I can't imagine all their driver boards are bad and they do have the needed coil voltage available. I just assumed the poper contact came in and fired the individual driver boards.
The missing scoring of targets is a function of the Driver Board? Any idea of the mapping so that I can replace the needed chip &/or transistor.
Are the sounds driven by the sound board alone or is the driver board involved as well?
Thanks for your help. Lots to consider. - Tom
20191230_180226 (resized).jpg20200101_235103 (resized).jpg20191230_180210 (resized).jpg20191230_180205 (resized).jpg20200101_234600 (resized).jpg
