Hey All - I'm working on a Panthera, and I'm having a bit of an odd issue. The leftmost drop target bank is trying to reset, but it seems too weak to complete the action. It is definitely receiving the command to perform the reset at the proper time, but just doesn't seem to have the umph to do it. The coil sleeve has been replaced and the plunger moves freely as it should, so it's not mechanical in that sense from what I can tell.
I grounded the tab on the driver board (a Rotten dog board) and the coil fires perfectly fine, with full strength. It resets the targets with no issue. So I know the coil can do the job, but for some reason doesn't seem to have the strength to do so when it should during a game.
Anyone have thoughts on what might be causing this?
