Hey guys are the first generation system 80 cpu boards compatible with second generation system 80 pins? Specifically can you put a cpu board from a Spider-Man into a Black Hole? Thanks in advance
Yes, I think you should be able to swap the MPU between those two games. Just keep in mind the MPU might have been swapped out at some point of its life with a different one, so it might even be a later board version anyway.
Do you know which board version you actually have? Each board revision should have a detail number on it. They're listed here:
https://www.pinwiki.com/wiki/index.php?title=Gottlieb_System_80#1st_Generation_CPU_Board
Quoted from ForceFlow:Yes, I think you should be able to swap the MPU between those two games. Just keep in mind the MPU might have been swapped out at some point of its life with a different one, so it might even be a later board version anyway.
I’ll check it out later today. Thanks for the input
This page was printed from https://pinside.com/pinball/forum/topic/system-80-cpu-compatibility- and we tried optimising it for printing. Some page elements may have been deliberately hidden.
