(Topic ID: 305930)
System 80 constant melody on power up
By CraigJam
1 year ago
  • 8 posts
  • 3 Pinsiders participating
  • Latest reply 1 year ago by CraigJam
#1 1 year ago
I am new to System 80 games and have a couple I am working on. The first is a 1980 Circus. I replaced the CPU with a Ni-wumpf and it appears to work great. I replaced corroded edge connectors as well. My issue is, upon power up a melody begins playing and never stops. I am not certain how these boards operate so I don’t know exactly where to start. The capacitors test fine and the voltages are sufficient at the sound board.
Has anyone had this specific problem?
Thanks for any help!
#2 1 year ago
Check the coin and start switches. Sounds like something is stuck
#3 1 year ago
Quoted from Cheddar:
I will take a look. Thanks!
#4 1 year ago
Quoted from CraigJam:
I took out the coin mechs and checked switches and they are normal. If I remove “A3-J5” from the driver board the music goes away. Otherwise it stays on.
#5 1 year ago
A3J5 drives coils so that's to be expected.
Try this. Boot up with A1J6 (Switch Matrix) disconnected. If it still does it replace it and remove A1J5 (Cab Switches). If removing either of these makes it stop then there is a stuck switch somewhere. It would be time to pull A3J5 (for the quiet) and put the game in switch test so you can see what's active
#6 1 year ago
I will try it tonight. I appreciate your help!
#7 1 year ago
Likely a silly question but is it playing like it's in attraction mode? Have you looked at your dip switch settings
#8 1 year ago
Quoted from RWH:
I was wondering if settings could be involved. I have a Ni-wumpf board so the settings aren’t like the original CPU. The sound board has two switches on it. One of them make the sound change to a pulsing tone, the other has no effect. If I do a sound test on the game the only sound I hear is the melody.
Men
2,000
Omaha, NE
$ 83.00
PinballReplacementParts
$ 11.00
Men
This page was printed from https://pinside.com/pinball/forum/topic/system-80-constant-melody-on-power-up and we tried optimising it for printing. Some page elements may have been deliberately hidden.
