My jungle lord has been playing great but now it has developed an issue where it boots into audit mode only. You can runt through the audits and it may go into attract mode or it may go back into audit. You run through the audits again and then it will go into attract mode and you can play. Will not hold the free play setting from turning off to turning on. I put original boards back into the machine and pulled out the pinballpcb boards because I wanted to be as original as possible. Any suggestions would be appreciated.
