For a black knight system 7.
I thought I solved this issue but I didnt. I put a memory cap in and put a 0 ohm jumper in at d17. The voltage at the positive side of the memory cap is 5v. Voltage at the jumper at d17 is 5v. Voltage at ic19 pin 22 the cmos ram is 5v. Ground to the memory cap has continuity to the ground braid.
It will hold memory for a short period of time. I'm not exactly sure how long, at least 15 minutes. But not overnight. In trying to diagnose this I know it may be the ic19 chip 5101 cmos ram. But before I go replacing it I want to run it by the pros on here.
Something I found odd is the coin door lockout switch/button is missing. The wires have been soldered together by the previous owner. Im not sure if this may be causing the game to boot into audit mode. I provided a picture of the wires I believe go to thee coin door lock out switch. Any help is greatly appreciated. 20140516_124450.jpg
