I have a working CPU board.
The driver board has its 40-pin connector replaced.
In essence the game is working as it should, but.......
When I turn the game power on, it blows the solenoids fuse.
If I pull all the solenoid connectors (2J9, 2J11 and 2J12) and then turn the power on all is good.
One by one (with the game on) I re-connect the connectors and all is fine.
I can play a game, all solenoids are working.
No burned out coils, everything is fine.
Just to be sure I've got the Blanking signal on the driver board, I connected a led and a resistor.
Now I can see the Blanking staying low on boot and go high after 1/2 a second.
The funny thing is that during the 1/2 second ALL solenoids are activated.
I've checked it by connecting only the first pin of 2J9 to a pin on the board.
The corresponding coil (a single drop target reset) activates for that 1/2 second until the Blanking goes high.
Then the coil deactivates and I can reconnect all to play a game.
Can someone help me in the right direction?
Peter
www.inkochnito.nl
