Hello, I'm reposting this from RGP to see if I can get some more help on this problem. I have a black knight that refuses to recognize the balls in the upper ball lock. However, in test mode all switches work perfectly. In a game, I can manually load 3 balls into the trough and it will start multiball. If manually loading 1 or 2 balls, the game does not respond, and does not kick a ball into the shooter lane. All Solenoids are working properly in test.
Here is what I've tried:
-2 Different Driver boards
-2 Different MPUs (1 brand new Kohout Repro)
-Tested each switch individually = No closed switch causes another switch to register.
-Removing all 3 balls and raising all drops = No stuck switches
-Verified all switches are reporting their correct # in the matrix
-Verfied wire colors and diode direction going to switches.
-Triple checked main trough switches are functioning and wired correctly.
-Switch connectors to driverboard reseated, wiggled, etc. (work in test, there is continuity)
All switch tests were done with a real ball.
I'm out of ideas, please help!
Post edited by catboxer : It Fricken Works!
