(Topic ID: 277719)
System 6 Sound/speach board problems
By zapdbf
  • 6 posts
  • 4 Pinsiders participating
  • Latest reply 3 years ago by PINTEC
#1 3 years ago
I am a tech, i am looking for another tech to help that has worked on these boards before. Here is where i stand with this board.
when the board is idle a9-a10 is active. When i press the test button all address lines become active for a moment then go back to inactive, i have confirmed this behavior with a working board other than the other data lines remain active. It seems to me something is stopping the code and making it return to the stand by state.
I have compared all the eproms to original code and there are no errors. Tested the ram it is good, also have tested the pia 6821 it is good. amp is working. During operation i have checked the logic of all the simple logic ic's, removed the 7445 tested it it is ok. data and address lines seem to be getting to all the ic's. What can i be missing?
#2 3 years ago
Quoted from zapdbf:
Watch the PIA ports going to the DAC when you push the sound test button and compare to a working board. That should tell you if the digital side is working OK.
#3 3 years ago
Are both boards configured with or without the speech board? Switch and jumper settings the same?
Check that the dip switches are working properly (pull pin 15 and 16 on the PIA high and/or low)
What problem are you having with the non-working board?
Probing A10 and A11 on the CPU chip or on one of the ROMs/RAM?
#4 3 years ago
Both have speech board attached. The problem is no sound when the test switch is pressed. all roms/ram passed testing.
#5 3 years ago
Did you try swapping the CPU chips from the working board to the non-working board?
Probe pin 4 of IC13 during speech test to see if there is activity.
#6 3 years ago
Quoted from zapdbf:
At your convenience send a photo of the front side of board
Metal-Mods
$ 129.00
Cabinet Parts
Bob's Pinball Stuff
2,500 (OBO)
Vista, CA
$ 53.95
$ 135.00
Sparky Pinball
$ 1,059.00
$ 59.95
Hookedonpinball.com
$ 69.00
Pinball Pimp
$ 69.00
Pinball Pimp
$ 17.00
Metal-Mods
$ 18.95
Hookedonpinball.com
$ 95.00
Pinball Mod Co.
Newcastle, OK
$ 959.00
$ 115.00
This page was printed from https://pinside.com/pinball/forum/topic/system-6-sound-speach-board-problems and we tried optimising it for printing. Some page elements may have been deliberately hidden.
