Hi, gang.
I have faulty sounds on my Gorgar, but its not because of the soundboard. The problem is on the driver board. I've swapped a good driver board into it and it works just fine. The sound solenoids trigger appropriately when you ground the transistor tabs, but most of the game sounds are wrong. I've swapped the PIA and installed new 7408s that drive those transistors... and pre and main transistors also test correctly. Really strange problem.
