GI lighting works but no track lighting..
Tried changing the batteries yet, and have you given the battery holder a close inspection. Those factory holders fall apart on a fairly regular basis.
Tried rapidly turning the power off then back on?
With the coin door open, what do the CPU board LED's do when you hit the diagnostic button?
-Hans
Did this happen when you changed the batteries? Can you advance through the diag settings? If it lost it's settings, you might just need to set everything (including free play). I just did this and I thought I screwed up for a second until I realized I just needed to reset all the values in settings.
http://pinside.com/pinball/forum/topic/vids-guide-to-bulletproofing-williams-system-6
If you're using pinside to get help fixing machines to flip you should probably consider making a donation
This page was printed from https://pinside.com/pinball/forum/topic/system-6-game-is-stuck-in-diagnostic-mode-help and we tried optimising it for printing. Some page elements may have been deliberately hidden.
