Are you a System 6 wizard? then here's a good one for you
Blackout driver board, recently serviced by pinball_services (eBay), has been working normally for a few days then both flippers stopped working...
I swapped it out with another driver board (from my working Firepower) and Blackout was back in business. Then I tried the bad driver board in my Firepower and got the same symptoms: everything works but the flippers. This driver board is the obvious culprit.
So I replaced R25, R26, R27, diode D1, Q13 transistor, flippers relay, and even the 7402N close by... But flippers are still dead.
What can I do? anything that I missed and that I should check? any test that could point me in the right direction? I would prefer to not return that board again for service (already spent a lot on it), I have some decent soldering/desoldering equipment but no logic probe, I can only do basic voltmeter testing.
I'm a bit desperate so any help appreciated Thanks
Few pics for reference :
