(Topic ID: 53679)
System 6 - Coil Voltage Too High - Bridge Rectifier?
By dtown
6 years ago
  • 8 posts
  • 5 Pinsiders participating
  • Latest reply 6 years ago by dtown
#1 6 years ago
I performed the fused bridge mod on my Firepower and I keep blowing the 4 amp fuse for BR2, the coil fuse. I can play for about a minute and then the coils go dead after the fuse blows. The 2.5 on the P/S board is fine. I measure 40 volts DC coming from BR2 which is way higher than the 28 that it should be. Is the bridge shot? Is this causing the fuse to blow?
I also measure 17 volts and 18 volts at the two AC lugs going into the bridge. Schematics say it should be 25.5 AC. Problem with the transformer? I doubt it but just putting it out there.
#2 6 years ago
Voltage going out not under load tends to be higher.
Don't know how you are measuring AC, hot to common ?
But voltage in is usually closer to voltage out.
#3 6 years ago
check the end of stroke switches on the flippers and make sure they open up. Make sure all grounds,specifically between head and cabinet are connected and solid.
#4 6 years ago
Not really too out of whack for a system 6, mine is in the mid 30v range I believe, not sure if a 4A is enough for that circuit to be honest, IIRC I'm running 8A
-Hans
#5 6 years ago
I got 40 volts at the coil lugs. It's actually 41-42 at BR2. I bypassed the mod and its not blowing the 2.5 amp fuse on the P/S. The mod called for 4 amp slow blows. Maybe it's not enough. This was a dead game so all switches and coils were checked and cleand prior to powering on.
#6 6 years ago
I found two different repair sites which describe the mod. One says to use 4 amp slow blows and the other says 8 amp. Which is it? I'm guessing 8.
One is Mark's Pinball Page - 4 amp
The other is easypinballpro - 8 amp
Easypinballpro mentions that Mark helped write the site so I'm at a loss.
#7 6 years ago
Below is part of a write up that I used the first few times I added the fuses to the rectifers. It says 8 amp.
#8 6 years ago
Thanks. I wish I had read the right one the first time. Out two fuses for misprinted instructions.
$ 22.00
1,600 (OBO)
Lizella, GA
Siegecraft Electronics
$ 14.99
PinballElectronics.com
$ 14.00
Yorktown Parts and Equip
$ 17.00
$ 18.00
Top-Notch Target Shields
