Hi everyone
Trying to diagnose issues with a System 3 sound board. I got this board with a bunch of spare boards in totally unknown condition. I placed it into my Tee'd Off and it did not boot. The main LED was locked on and pressing reset did nothing.
So, I connected the board to my test bench with Marco's test ROMs installed. With the test LED connected to pin 17 of T3, when power is turned on, the test LED locks on and the main LED stays off. Pressing reset makes the test LED dim momentarily before it locks on again. The main LED doesn't change.
With the test LED connected to pin 17 of N1, when power is turned on, the test LED starts to flash and the main LED stays off. This looks to me like the board is waiting for input/reset. When I press reset, the test LED dims and stays that way. No change to the main LED.
So it seems to me that when hooked into N1, the test ROMs attempt to boot the board, while they do nothing when hooked up to T3. I have already replaced H2 and H3. I have also tested A3, which appears to be good. It seems to me that the 6502 at T3 is the most likely suspect. If I need to replace this, can I replace it with a faster processor or do I need to stick with 2 Mhz? Faster processors are more readily available, and cheaper.
What do you guys think? Thanks in advance for any advice.
