(Topic ID: 301722)
System 3 diagnostics issue
By bestofthebunch
2 years ago
    #1 2 years ago
    Hi
    I have a Luck Seven (system 3 Williams) boots / plays no issues on original board set. To go into diagnostics on a system 3 you have to get to audits 04-?? and put into Auto so the audits scroll through. Press advance twice at about 1/2 sec interval and hey presto .. displays go out as expected. But when you press the advance again nothing, displays remain blank and I have to switch off and back on to boot into attract again . Any ideas
    #2 2 years ago
    Quoted from bestofthebunch:
    Hi
    To get into lamp,solenoid,switch tests Lucky 7:
    In game over mode set the auto Up/Down to: DOWN next goto the cpu board Press the diagnostics button on right edge of board,the leds should blink twice quickly.
    Next go back to the coin door select auto UP and press advance to go thru tests.
    #3 2 years ago
    Hi I’ve done that but after the displays go blank they then don’t do anything when you press again, it doesn’t go into the display test … etc
    #4 2 years ago
    Found the issue the connector for the switches was dirty and not registering properly
    This page was printed from https://pinside.com/pinball/forum/topic/system-3-diagnostics-issue and we tried optimising it for printing. Some page elements may have been deliberately hidden.
