I have some fully-functioning bright plasma system 9 alpha numeric displays in my Sorcerer that are failing to mount flat and vertical: Two problems:
1. When screwed in tight, they lean forward, and are no longer "well-glued together" - so they can scratch the backglass, and remove art.
2. They have no gaskets on them so they scratch the backglass.
So far, I've made sure my lamp board is mounted properly, and there's a good distance between the displays and the backglass, but they keep leaning forward.
1. Can someone speak to getting displays to lay flat again? glue? double-sided tape?
2. Are those gaskets that are glued on there obtainable? If not -- are there any other options beyond weather stripping?
thanks,
mof
I'll post some sad pictures later tonight...
