Working on a Bally GameShow and have multiple issues so sorry if this gets confusing.
With original MPU game will boot and play with a few issues:
1) On Left display only, Segments A and B (see pic) on all digits will not lite. Display and ribbon cable have been tested in another machine and work and spare MPU has been used and display works as it should so I'm assuming it's an issue on the original MPU. Where to go from here?
2)After game warms up (a minute or few) ball trough kickover coil will stutter and tend to lock on. Corresponding switch works proper in test. Transistor and pre driver replaced and same issue. Using a spare MPU it works as it should. What should I be looking at on original MPU?
3) Ball trough up-kick to shooter lane coil doesn't work in game or test mode. Transistor replaced and pre driver. Corresponding switches register in test. Grounding transistor fires coil (original mpu) and using spare MPU it works as it should. Where to test next?
4) Solenoid 16 - Backbox teeth and title Flashers do not work. 4 flashers total in chain. With meter probe on ground strap and either of the socket lugs I'm getting like 42Volts DC on all 4. Bulbs are not blown. Grounded the center lug on one socket and all 4 instantly blew. These do not work with spare mpu installed either???
WITH SPARE MPU (think it's an 11B but have to look again) installed:
- issues 1 through 3 above go away - issue 4 above consistent
- NEW PROBLEM - ALL "Special" Solenoids do not work. All worked with original mpu. 3 pop bumpers and 2 slings. All corresponding switches work proper in test and if I ground all transistors all coils fire. Transistors are all in spec. All located in same area on board (see red circle on pic). Replace a chip?
Any help appreciated. thanks
Resized952023053195172402 (resized).jpgResized952023060395183134 (resized).jpgResized952023060495201747 (resized).jpg
