Ok, new to CB troubleshooting (so please bear with me) but I do have electrical background as an HVAC tech for 25 years.
Problem: System 11b board wont boot-no blanking light, only 5 volt light. I believe MPU is running, based on a lot of activity on U 15, 26 &27. (26 & 27 GET HOT TO TOUCH)
Previous work has been done, some driver transistors and ICs U44,45 have been replaced.
Trace jumpers have been installed.
Q 72 and 73, associated resistors and diodes were smoked. When I bought the machine I hoped just replacing the smoked components would solve issue.
First, relocated on board battery pack, although no damage was present .
Second, replaced smoked components mentioned above, Ohmed out traces, powered up did not work.
Third, replaced 6802 Mpu chip.nope....
Fourth, U 43, same result.
Fifth, U 55, same...
No go.
I hooked my logic probe up to a working system 11a board. Checking U51 pin 4 - U44 pin 21- and U43 pin 3, they all pulse the same. On my System 11b board that isnt working, they all probe high. I assume they should all be pulsing like the board in my Tomcat that works. Where should I look to try and diagnose why the signal is not pulsing as it should?
