Thank all you guys for your advice! I greatly appreciate it! I'm going to check everything you guys said and cover those diode ends. Now that I have the board out again, I'm going to follow every wire, clean them, and inspect them with a fine tooth comb. BTW Viper is correct, I did a playfield swap and rebuilt everything attached to the playfield. Everything is almost new, as a matter of fact the whole top of the playfield is completely new. As soon as I finish I'll perform a coil test just to see if the flashers light up. I would also like to ad, when I bought the pinball machine everything was fine for about a month. The gi fuse started blowing. At that time I decided to replace the playfield. I found one of the relays was burnt up from solder that had fallen on it, and I found the same with some light sockets. After I finished the board the gi problem still remained. I replaced the power supply and everything was fine for about 2 weeks, and then the gi lights went out again. Now not only are the gi fuses blowing, when I hit the flippers the flashers light up.
I want to thank you all again!
I just noticed this, does it make a difference? Pictures are larger now too.
Here you go GRUMPY
