Picked up a Game Show light project.
Fixed all the interconnect board lighting issues.
Has a new system 11 rottendog board because the old one was battery damaged. (problem existed before this board was installed when my friend owned it).
Center coil lugs have 70v
If the backbox mounted bridge rectifier goes to the flippers (i suspect it does), appears to have just under 13v AC in and 6.5v out DC.
All fuses test good out of circuit.
Continuity on all wires from A to B is intact.
Solenoid table does not have a transistor associated with the flipper coils
I've had a lot of system 11's, all projects (which is what i prefer), but i've never had a situation where the flippers did nothing at all.
I'm an electrician, so i can test whatever you guys want me too.
Other issues that i have yet to sort out is right sling doesn't work, neither does one of the pop bumpers. I've yet to look into these issues.
For the most part, this game starts and plays as it should, just with no flippers.
Thanks for any help,
Joe
Edit: Fixed the sling and pop bumper, both just had wires that broke off the lugs.
