i have a pinbot that locks a jet bumper coil on when you power up. Everything checks out "fine" so I was going to throw some parts at it see what fixed it. I'm reading I should check the caps and diodes in the "special" section of the board but I'm getting 3 different parts for the caps c70-c75. Manual read .1 mfd 50v, parts list online reads .01uf 50v, and rec games forum said 1 mfd 50v. If the manual actually listing a milliferad cap or is it actually a .1 uf and I should just use the same caps I have for the WPC boards?
