Here is the short version
Before doing work, q69 was roasted but everything else worked and no fuses blew. After attempting to fix... more issues.
Now all special solenoid drive transistors except one have a open path to ground with connector J19 connected but do not with it disconnected. Fuse special solenoid fuse on power driver blows if J19 is connected. Is SN74F02N a compatible replacement for 7402 and U45?
More complete description
I have been fighting with a new to me Pinbot's special solenoids. after removing everything top side of the playfield, cleaning it, and re-assemblng, I started the solenoid tests. The left sling shot wouldn't fire so I opened up the backbox and noticed the typical roasted transistor (Q69) for this left sling special solenoid. So I took the board out and changed Q69 and the predriver. While I was at it I changed all the caps on the PSB board as well. I started a game and again the left slingshot would not fire and it appeared the transistor burnt up again. I say appears because now I am unsure, but keep reading. This time I changed the transistor, the resistors at R93-R94, and the 7402 chip at u45. I used a SN74F02N, perhaps that is the issue but I was told it is a valid replacement in this scenario.
Now when I try to play test, it seems any of the special solenoids will cause the fuse to blow on the PSB. So I did a quick test on each of the special solenoid drive transistors by checking continuity to ground and ALL OF THEM except one had continuity with ground with the game off and everything plugged in. Removed the board and checked them and all came up fine and not grounded except q69. So then I plugged in ONLY J19 and they all had path to ground again.
I am kind of out of ideas. It seems I have a short here but I cannot find it. Unless another component has failed or the SN74F02N won't work in this application.
I am willing to start completely over with my trouble shooting. It seems I have made things worse. This is far from my first system 11 repair and my second pinbot. But it's best to pretend I know nothing. I can't wait to figure out what simple thing I am overlooking.
