(Topic ID: 161117)
System 11 Space Station Power Supply Question
By Chosen_S
6 years ago
  • 4 posts
  • 2 Pinsiders participating
  • Latest reply 6 years ago by Chosen_S
#1 6 years ago
I'm rebuilding my Space Station power supply... I had gotten all of the parts from my local electronics store... they had matched up the transistors the best they could and I'm curious if two of the transistors they gave me will actually work...
Q3 on the power Supply calls for a SDS202, pnp, or MJE15031... my PS has the 15031.
also Q1 calls for SDS201, NPN, or MJE15030...
I was supplied with an NTE55, will this work in place of the 15031?
I was also supplied with an EGC171, will this work in place of 15030?
Thank you for any help
#2 6 years ago
If you compare the two datasheets:
http://www.nteinc.com/specs/10to99/pdf/nte54.pdf
http://www.mouser.com/ds/2/308/MJE15028-D-110804.pdf
They have similar max ratings and electrical characteristics. I think the NTE one would be ok, but I couldn't find a datasheet for ECG171, so not sure on that one.
MJE340/350 also will replace these transistors, are cheaper by 1/3, and can be installed standing up, rather that cross-legged (may depend on your board).
https://greatplainselectronics.com/products.asp?cat=103
Be aware that any replacements may have different pin arrangements than the originals, so make sure you install them correctly. Sometimes you have to line up the legs differently to fit the right holes. For further confusion, the boards are not all the same, some had holes arranged differently, and some had holes for two types of transistors. Best thing to do is get the schematic, and label the BCE holes on your board accordingly, then figure out the best way to line up your replacement transistor legs. You may be able to stand the transistors up, or may need to cross legs to get them in the right holes.
#3 6 years ago
I confirmed nte55 works for mje15030
Egc171 does not work for mje15030
#4 6 years ago
Quoted from KenH:
Thank you so much for looking at this with me, space station is up and running again!
$ 54.99
Shooter rods
$ 18.95
3,200 (Firm)
Portland, OR
$ 54.99
Shooter rods
Strongsville, OH
$ 27.95
West Chicago, IL
$ 69.99
Pinball Shark
Shooter rods
$ 52.99
Pinball Shark
Shooter rods
Men
Orchard Lake Village, MI
Other
This page was printed from https://pinside.com/pinball/forum/topic/system-11-space-station-power-supply-question and we tried optimising it for printing. Some page elements may have been deliberately hidden.
