I picked up an F-14 and discovered the upper diverter coil was fried (the sleeve had melted into a ball inside). I've replaced the coil but before I fire it up I'm looking into what may have caused it to fry.
Both the Q77 and Q76 transistors had been replaced by a previous owner. The U50 looks original.
Before pulling those two transistors out for testing, I decided to check other components in the circuit, and discovered that R102 was reading at about half of what the same resistor in the other solenoid circuits were reading (about 1k ohms rather than 2k; it's supposed to be a 2.7k ohm resistor).
I lifted one leg and it read over 2k. I replaced the resistor and and the new one also read about 1k in circuit.
Any ideas on why of the six similar circuits only this resistor would be behaving this way? Is it even relevant?
Since both transistors had been replaced before, I'm wondering if that's not the problem.
