My Space Station has the bug where 75% of the time, at the first power on you'll either get no displays or a random error... but an immediate flick of the power switch boots the game normally and it plays 100% fine for however long you want, hours on end. The other 25% of the time it boots fine on the first attempt. It's done this for nearly a year.
I finally stumbled on the solution to this problem in the Sys11 club thread: replace the 22uF/25V cap at C30. Ha! Too easy to ignore, so I did this.
When I installed the repaired board and turned the game on, it failed to boot, I heard a coil pop then fuse F5 on the power supply blew. Using a 7A breaker in this location, it immediately trips when I try to start the game. During repeated cycle troubleshooting / while removing loads from the PSU, eventually F6 blew as well. Even with all loads disconnected from the PSU, F5 still blows.
Confirming a suspicion, I consulted the tech guides and say this indeed means that the PSU bridge rectifier has shorted out. OK. I can test and replace that, but...
... is this just a wild freaking coincidence, or could something I might have botched (and for god's sake I'm afraid to ask what?) in replacing one stupid cap at MPU C30, have caused this? (In other words, if I fix the PSU and hook it back up... could it blow again?)
