I have replaced the most of the caps and I just replaced R4 AND R1 resistors. Everything on the playfield is lite but no scoring display on all 4 displays. The display came on for a "few" 2-3 seconds at best and not the entire display. I tested the pins again after that, they are as follows...
Orange= Negative 100v is at .8
Brown= +100v is at 98.6
Gray= +5 is at 4.98
It must have a lot to do with the orange coming in at .8, but where do I go from here?
I assume the resistors are correct the spec are the same but the center color is different. Orginal (gold,red, white, orange). The new ones were (gold,black,white, orange) does that make a difference?
Also after I replaced the parts above it will not start a game when I push start. If I start the test mode all sounds and light work? What could have happened?
