(Topic ID: 110157)
System 11 power in a Alpha Numeric Data East
By CadillacMusic
9 years ago
#1 9 years ago
Got a customer's DE playboy with 3.8v on the 5 volts, and some interesting arcs on startup. I need to replace its power board. I don't have any spare Data East ones from that era. I've seen various places that you can stick a williams 11 power board in place of the 5000 DE one. Is it any system 11 power board? I think I have the right ones, but I want to make sure. Are any modifications needed? Or can I just pull it out of a Diner or a Cyclone, and plunk it in?
#2 9 years ago
For a DE Playboy, the earlier WMS Sys11 PS (think Cyclone, Pinbot) should plug right in.
The Diner style is the newer PS, like Taxi - end of sys11 use, and won't be pinout compatible.
I would suggest that you verify the fuse values to the manual before installing it, as I've repaired a ton of these, and don't think I've had many with correct rated fuses installed, and also hook up the inputs and check the output voltages before hooking the outputs up.
#3 9 years ago
Fair enough. Cyclone, I shall test ye! Thank you.
$ 27.95
$ 18.95
$ 18.95
Great pinball charity
Pinball Edu
This page was printed from https://pinside.com/pinball/forum/topic/system-11-power-in-a-alpha-numeric-data-east and we tried optimising it for printing. Some page elements may have been deliberately hidden.
