I am having a problem with the upper left lockout hole. It’s Q25. The game is police force. The ball will go in but the coil will not fire to kick it out. I ohmed the coil it checked out fine. I checked the transistor it’s good also. With the game on and a ball in the hole the relay on the PPb board keeps clicking. If you ground the transistor the flasher will light and if you ground it when the relay clicks it will fire the coil. Switch is working as it should. Any ideas? Thanks in advance.
