Is there a way to test the flasher lamps? When I run lamp test/all it does not light the flashers.
Flasher test on system 11's is probably in coil test. Run through it and it should test your flashers in between each of the coils.
That makes sense, I will check it out. Is there a way to stop the test when it hits a certain coil (or lamps)?
This page was printed from https://pinside.com/pinball/forum/topic/system-11-lamp-test and we tried optimising it for printing. Some page elements may have been deliberately hidden.
