I'm trying to figure out where I went wrong with my power supply.
I have an Alley Cats that had intermittent light issues. Replaced the header pins on the power supply boards and had complete success! Until the small piece of Flux I missed while cleaning caused two pins to arc together. This can be seen in the attached. Oops.
Much shame and diagnosis later I realized I had an issue with the high voltage section. At 3J5 I should have -100V, +100V, and +5V. I had -100V, a fluctuating voltage at pin #4 where I should have had +100V, and +5V.
Figuring that my high voltage section needed rebuilding, I replaced diodes and resistors for the 91V mod as per Vid's handy bulletproofing guide.
...I now have no voltage at pins 4/3, where I should have -/+ 100V or now 91V. When I read it with a DMM, they read 60ish volts, then drop to 0V over a few seconds.
I'm stumped. I have continuity as far as I can see. Please help!
