I understand it all. Thanks Vid.
New bumper skirts, rings, bodies, etc..all can add to a 1mm-2mm height variance, causing the short.
First, Stats, we have 12 rings back, that people have had an issue, with a large amount sold, so about
2% or less have experienced this.
We check each one going out.
Most rings do not need hot glue to the cap, but some do shift around. It isnt possible to say which
one with so many different caps, manufacturers, wear, replacement/original bodies.
But all these can possibly mean, someone who installs could have this issue.
Sounds like normal pinball, that trying to make something 100% perfect for 35 years of games will have bumps, but right here to address it.
With your help fiftyquid, since you dont have a working one, we can try another if you wish, and glue to cap, raise slightly, adjust brightness, and cover pot.
I honestly believe this should work.
I will test, if I can duplicate this weekend.
IF we succeed, then we can share with anyone else who might have this experience.
